Line into segments
Command
Path
Line into Segments
Modify > Drafting Aids
The Line into Segments command converts a selected line into the indicated number of equal length segments. The original line can be converted, or an identical line placed on top of the original and converted.
To convert a line into segments:
Select the line to be converted.
Select the command.
The Line into Segments dialog box opens.
Parameter
Description
Place loci
Places loci at the segment divisions
Break Line Into Segments
Creates segments from the original line, converting it; deselect to place loci only
Leave Original Line Intact
Retains the original line, and creates segments from a copy of the line
Number of Segments
Specifies the number of segments to create
Set the parameters and draw either a new segmented line or convert the selected one.
Creating single lines
Creating double lines
Create dividing lines
